Zum Hauptinhalt wechseln
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 Fragen Alle anzeigen
problem with can't power up panasonic toughbook cf-29
i can't power up after battery was charged.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
On most toughbooks please follow these instructions in order:
Step 1: Please Un-Plug AC Adapter (External Power Supply).
Step 2: Please Remove Internal Toughbook Battery Pack
(In some cases, you must release the latch located on the underside of the Toughbook).
Step 3: Do not put back the internal battery but plug back in the AC Adapter.
Step 4: Turn on the power (ie. start-up the Toughbook with the power button).
(In most cases the Toughbook will turn back on without the internal battery pack).
Step 5: Once the Toughbook is powered back on, do a complete shutdown of Windows.
Step 6: Put back the internal battery pack.
That is it. Your Toughbook should now work as normal.
Good Luck and Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
War diese Antwort hilfreich?
Bewertung 3
10 Kommentare:
Perfect! You fixed me, thank you.
von
it worked for me, you saved my 3 Panasonic CF 54. thanks.
von
Worked on Panasonic CF-AX2. thanks.
von
Try already. But Can not ON
von
Is toughbook On without battery??
von
5 weitere Kommentare anzeigen
Antwort hinzufügen
drhaswell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 8
Letzten 7 Tage: 65
Letzten 30 Tage: 292
Insgesamt: 14,453
