Zum Hauptinhalt wechseln
Überarbeitung der Xbox 360-Reihe von Spielekonsolen (Version Mitte 2013) mit 4 USB-Anschlüssen und integrierter Wi-Fi-Konnektivität.
69 Fragen Alle anzeigen
Why are the controllers not syncing?
My xbox 360 turns on to the home screen if i push the power button, but the green light isn't going on and the controllers aren't syncing to the system. They turn on but don't sync to the system.
Ist dies eine gute Frage?
Bewertung 1
Kommentare:
Have you tried a factory reset of the console?
von
How do you do that?
von
Apologies I thought it was an Xbox One you had. For the 360 you can only format the drive. Can you use the controllers if you plug in the charge cable?
von
no clue, the light for the power doesnt come on and the controllers dont work even if they are plugged in but the power lights come on but stay rotating like they do when they are trying to sync
von
I have exactly same problem I had mines for 4 months 360 crap were u ever able to find fix
von
Einen Kommentar hinzufügen
2 Antworten
You have to go and find a small button on the console which has two arrows that is to sync. Now find it on your controller and press the button at the same time. Then it should sync. But if your console is not turning on maybe youn have overheated it or maybe some wires are out.
War diese Antwort hilfreich?
Bewertung 0
Might not be the same issue but I have a good controller that wasn’t connecting to a 360 and the issue for me was the little board on the front of the console with the power button on it. Pretty easy to take apart and get at, you can buy the boards for like $4 to $5 used.
Bewertung 0
Antwort hinzufügen
flamevanity wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 8
Letzten 30 Tage: 28
Insgesamt: 2,408
