Zum Hauptinhalt wechseln
The TDK Trek Max is a wireless portable speaker complete with Bluetooth capabilities. The integrated microphone allows for speakerphone capabilities to any device that is currently paired to the speaker via Bluetooth or that is plugged into it. The auxiliary and USB ports make the speaker compatible with almost any device.
9 Fragen Alle anzeigen
Why won't my speaker turn on?
I have had the device plugged in all day and it still won't turn on. My brother has the same speaker and uses my charger so I know that is not the problem. I'm thinking the battery is dead or maybe the charge port is malfunctioning. What can I do?
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
I saw you mentioned the sound was low on this speaker in another thread, did you get the power issue resolved then?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
If the speaker is not turning on after a full charge it could be suffering from a battery malfunction. Follow our guide on battery replacement to fix this issue.
War diese Antwort hilfreich?
Bewertung 1
Trek max will work even without a battery connected. (power supply must be connected). I have one that works only when fully charged for a short time unless charger plugged in. This indicates a problem with battery voltage sensor. Same battery works fine in another unit. Your problem may be a worse case of this. I suggest Remove battery and test it.
Bewertung 0
1 Kommentar:
My Trek Max A34 will not charge. I thought it was the battery so I boughf a new one. That won’t charge either. Only way Trek Max will work is plugged in. How do I fix this issue?
von
Jag får inget ljud i högtalarna
Bewertung 0
Antwort hinzufügen
Rebecca wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 3,941
