I have same problem with an Acer Notebook (Aspire E5-575G from around 2016). During normal usage it instantly went completely OFF and never came back. Tried all version of cable-plug-in-out/power-button/battery-disconnect etc.
If I plug-in the power cable, the orange/blue LED are lighting and thus indicating battery is charging/full and mainboard is correctly powered. But if I now press the POWER Button the LED is flickering (gets a little bit darker, went off, and comes back within about 2 seconds). For me it seems as there is any short circuit / overload present on mainboard.
I opend the notebook and searched the mainboard for any obviously demages (died ELKOS, resistors etc), but could not see anything (but it is hard to distinguish). Made the above test with opened mainboard again: during this 2 seconds-LED-flickering-after-power-button-is-pressed I can hear a very silent noice/squeeze coming maybe from nearby the DIMM/RAM banks. PLUS: I noticed, that a certain component gets very hot, which in my eyes shold not happen. I marked this component on the picture (see below), labeled with “2R2 628 E47”. I guess it is an resistor? And I guess just changing this is most likely not the to solve the root cause. Anybody does know it better?
Maybe the most important point: the failure just happens 2 days after I had to use the notebook with an non-original power supply - and I guess this was the cause of failure. It was an older universal power supply with 100W and a voltage switch (12-24V, I of course just used the 19V setting, but maybe it is malfunctioning or have a bad DC signal…).
So bottom line: just use appropriate voltage supplies for your notebooks ;-)
For sake of completeness: I also changed CMOS/RTC battery (CR2032, 3V), but no change.
I think I will give up - and order a identical, used Notebook and will “just” switch my SSD.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
7 Kommentare
i have this problem too,i was playing game and suddenley my laptop turned off,i send my laptop to our Acer Representation and after two moth they couldnt find out whats the problem is so they tell me U should change the motherbord,
but it was too expensive
i try every thing(with battry/without battrey/with charger)but it still dont working :(
von sherwin
and if you know there is any way to ask from Acer company plz tell me
von sherwin
Hi need help about my acer laptop I just accidentally plug the earphone on the HDMI slot then it shut down the computer.When I turn it on nothings happen, only the charger and battery works. I've tried the 30 seconds reset but still nothing to show. Please help!
von Albert
hi everyone
my acer laptop fell and is not coming on
Can anyone help me please?
thanks
von rammybrad
My laptop E5-571/E5-531 m/b a5wah LA-B991P.
POWER 3.3V and 5,0v present when push power button after 3sec shutdown.Any coment or sugestion.thank.
von Jamari Ramlan
2 weitere Kommentare anzeigen
