Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
Tea spill prevents setup from DVD : wich board to replace?
After Tea spill over keyboard, my MacBook A1278 can power on every now and then but if I try to run or setup the system from Apple DVD it will turn off. Then I can't switch it on anymore. I wanted to start replacing the magsafe board first, does it make sense?
Also, how can I eject the DVD if the Mac doesn't power on?
Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Search for
liquid spill, liquid damage in the search box - there are many steps you should try (like cleaning and reassembly) before randomly shoving parts at it.
If the double sticky tape trick won't work you'll have to disassemble the drive (at least as far as removing the top)
If this answer was helpful please remember to mark it accepted.
Good Luck,
N.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for the tape trick.
von
Antwort hinzufügen
Andre wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 734
