Zum Hauptinhalt wechseln
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
PSP LCD replacement, do all the 300x series have the same LCD?
Hi,
Can't seem to find info on this online, does anyone know if the PSP 3008 screen is the same as the 3000, 3001, 3003, 3004?
Found a replacement for those models locally but not sure if it fits the 3008 (I believe this was a russian model)
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
How about psp 3000 version? The other psp 300x lcd also compatible?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
For anyone else looking for this answer, yes the 300x series are interchangeable. Ordered one that stated it was only suitable for the 3001,3003,3004 and worked flawlessly in the 3008 model.
War diese Antwort hilfreich?
Bewertung 0
does it work for the 3006?
Unique Usernam
Bewertung 0
I had bricked psp 3004. I bought a motherboard. It is ta 090. I changed motherboard. It was ta 094. After i power it up with new ta090 i have bad screen. https://ibb.co/eVten7 any ideas?
Bewertung 0
Tuna, I think you might have bent the cables coming out of the LCD screen. This is what has happened to my current PSP 3003 screen, when I was replacing the D-pad sensor; I must have accidentally mishandled the wiring, and now the screen looks exactly like yours. The only option you have is to replace the screen wholly with a new one, see ebay for cheaper alternatives.
Bewertung 0
Antwort hinzufügen
Brendan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 2,472
