Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
548 Fragen Alle anzeigen
Frage geschlossen
Something blew while diagnosing power supply ...help!
I opened up my iMac to diagnose whether I need to replace the power supply. I plugged it in to find the LED lights. When I pushed the power on button something blew on the power supply board. Will I have the same problem when I replace it? It smelled like something burned. I need to get my Mac up & running again. HELP!
I have an iMac A1224 emc 2133 2.4
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I'm level 1 repair barely. How & what do I check for shorts? There's no room in there. I had to have my husbands help to get a bad hard drive out & get it back in. All the videos make it look so easy, but it isn't. My son has a friend who knows PCs, don't know if he'd know what to do with a Mac. Or if he can get over his false PC superiority. I'm always telling them PC stands for piece of crap.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
you may need to replace your PSU
you can just replace few components but it's gonna be hard + it's Easy Level 3 repair
check whatever there are some fuses or blown traces or smth suspicious....
post some pictures what you found
you could replace your PSU but i won't guarante that it dosen't blow the $@$* out of it again...
i would preffer that we check what blow and why becouse if we have short circuit that that's gonna ruin your day
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
von
Level 3 means resoldering stuff on PCB (there are lvl 3 cases that an idiot who knows how to solder can do)
i think he can do it ! just belive in people, look i'm 18 and i know few thinks (i do that stuff since 12 or so...) but hey they need to learn even if they break stuff
to check shorts you need multimeter on contiunity setting (beeps) .....
i don't think you understand even 1/2 what i say so just
and spotting visual damages isn't hard if something is blown up you'll notice
von
What tools do. Need to track down a short? Soldering is easy, but in this case it's very tiny components. I check for shorts, but aren't there tools to help?
von
you can't check shorts with your finger xd
you'll need multimeter on continuity setting (just watch tutorian on multimeter)
track down? it's hard and gets expencive
first of all check for blown and dead stuff...and post fotos if you find anything
then get your dmm (digital multimeter) and while unplug look for the voltage lines like 5v;3.3v;12v(i don't know every single psu and what woltages it has...if you have problems i can post little video what i mean ) and gnd check them all and if you get a really low reading (or/and beep) than let us know
if you get any short don't power it on
if nothing try to power it on and check what happends?
after it's powered on check the voltages (black to gnd and ret to voltage line ) do it carefully so you don't get a zap
there may be tools but i don't know any
and check fuses for continuity whatever the aren't blown
do all the things with psu cable attached to the board and not attached to check if there is a short where it is on the main pcb or on the psu
let's hope you'r psu is dead and not anything so it'll be cheaper to replace (if it smells burned something is dead anyway )
(my text dosen't fit as a comment)
von
Hilfreichste Antwort
Mateusz
is 18 years old and can walk on water as all 18 year olds can. Just replace the part.
Here's how: iMac Intel 20" EMC 2133 und 2210 Netzteil tauschen
Here's the part: iMac Intel 20" 2.0/2.4 GHz EMC 2133 Power Supply
iMac Intel 20" 2.0/2.4 GHz EMC 2133 Power Supply Bild
Produkt
$29.99
Bewertung 1
3 Kommentare:
oh you'r really nice to me right now ?
if something blow on the main PCB than PSU seplacement won't help,
and i did say that PSU replacement may help but it's not 100% sure
i don't care if you can help so i'm letting this thread to you
von
I don't recall not being nice. But when you use so many abbreviations & broken English it's hard to understand anything you are saying. It doesn't mean I'm stupid, it means you're being arrogant. It's a problem too many tech people have. Kind of like comic book guy on the Simpsons.
von
I'm just buying an Apple repair manual that they use for training, because visual will be easier for me. I was told the diagnostic wouldn't be worth it because Apple parts are too expensive. I don't care if it's a part from Apple, just so it's compatible.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 259
