Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
Vertical Orangle line on Screen
My Macbook is showing a vertical orange line on screen. It's a constant line show up when the system starts (on the gray screen with apple logo) and continues till the system is turned off.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Honestly it sounds like you have a bad LCD Panel, there are some very thin ribbon cables that go around the outside edges of the panel, is it possible that the lid may have been stuck in a way to damage that cable?
Mark Grummell Indianapolis, IN
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
amurtiger is correct you have a bad LCD, it has what is known as a TAB fault. You should be able to find an LCD on eBay. Here are the replacement procedures: MacBook Core 2 Duo LCD Panel Replacement
von
Antwort hinzufügen
Nishchay Kumawat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,259
