Can't change direction of touchpad scrolling
ASUS K55A
Windows updated this morning and now the touchpad is scrolling in reverse (both left/right and up/down). I have gone into the ASUS Smart Gesture settings but whether "content moves reversely" is checked or unchecked, it has no effect on which direction the touchpad scrolls. I restarted, same thing. Entered the following commands into powershell with elevated permissions, restarted again but still no change.
Code:
Get-ItemProperty HKLM:\SYSTEM\CurrentControlSet\Enum\HID\*\*\Device` Parameters FlipFlopWheel -EA 0 | ForEach-Object { Set-ItemProperty $_.PSPath FlipFlopWheel 1 } Get-ItemProperty HKLM:\SYSTEM\CurrentControlSet\Enum\HID\*\*\Device` Parameters FlipFlopHScroll -EA 0 | ForEach-Object { Set-ItemProperty $_.PSPath FlipFlopHScroll 1 }
Any other ideas?
Ist dies eine gute Frage?
I would start by reinstalling your drivers for the touchpad.
von Hortman
Hi,
If "Hortman's" response doesn't work, maybe you should do a system restore back to just before the updates, see if the problem is gone, then re-install the update(s) one at a time to see which one caused the problem.
von jayeff
