MacBook Pro Power Adapter on a MacBook?
I found out from this lovely website that my repair centre has put magsafe of a MacBook Pro on my MacBook. What could be the consequences?
Ist dies eine gute Frage?
I've interchanged them for years. The only problem I've run into is using a 45 watt on one wanting a 65 watt. It doesn't charge the battery. Else wise I've experienced no problems.
War diese Antwort hilfreich?
Don't worry. A MacBook Pro adapter won't hurt a MacBook. It might even work better, since it won't get as hot. A MacBook adapter might fail to charge a MacBook Pro, and over time, might overheat, since a MacBook Pro requires more power than a MacBook. But the other way won't cause any problems, and might end up better for you.
I forgot to mention, magsafe board not magsafe charger...so my problem is the that repair guy has put 17" 1296 magsafe board on my 13" 1278 laptop.
Kindly help
I have killed an adapter trying to power more wattage than what it can deliver. Will be fine the other way.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,103
