Zum Hauptinhalt wechseln
Das iPad Air 2 ist der noch schlankere Nachfolger des iPad Air. Es wurde am 16. Oktober 2014 angekündigt.
448 Fragen Alle anzeigen
Air 2 has no power after screen replacement
This was my 4th Air 2 screen replacement and it was a normal repair, nothing weird happened. I cannot get the unit to turn on now. iTunes doesn't recognize it and when plugging it into a Apple charger it shows no sign of life. I pulled off the cover to check the components and found nothing to really be out of place. I used a loupe and took some pictures for you to check.
I have tried several hard resets, the original display and another OEM display. Nothing on the board got hit taking it out. No lights and no sounds from charging it.
I need ideas about what to check.
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
Did you use any metal tools when disconnecting the battery or LCD? Its ok if you did, just please be honest since this will really help troubleshoot this.
von
Same problem but I also changed the battery. And it wouldnt charge anymore. Would you happen to know a solution maybe?
von
Einen Kommentar hinzufügen
1 Antwort
I would make sure that the lightning connector is firmly connected. I would go as far as to disconnect and reconnect as a first step in troubleshooting
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Brian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 456
