Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Frage geschlossen
Why can't I unscrew the screws inside my phone.
I am needing to replace the battery (i think) of my 5s after it was soaked in water. none of the interior screws will unscrew, even though I've used a PH00 and a PH000. Any idea why this is happening?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I use a PH000 and work on iPhones every day. Are your screws covered in Corrosion? Was there a particular screw you were having trouble with?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you for answering my question. there is no visible corrosion on the screw. i got a different screwdriver and found that I really needed to put a lot of pressure on the screw to let it grip the screwdriver. i was finally able to get them out.
von
Hilfreichste Antwort
Get another PH #00 screwdriver. Take the iPhone to the hardware store so you can make sure the screws fit the screwdriver perfectly. Even 99c store screwdriver kits will work. Take iPhone there also, to be certain you get perfect fit so you don't have any more hassle then you have experienced already.
Bewertung 1
1 Kommentar:
Thanks for answering my question. I got a new screwdriver. what i found is that i needed to put a lot of pressure on the screwdriver to get a grip on the screw. they came out, finally!
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 723
