Zum Hauptinhalt wechseln
Apples Laptop-Serie für Nutzer:innen mit höheren Ansprüchen im beruflichen oder privaten Gebrauch. Bislang gibt es Modelle in den Größen 13, 14, 15, 16 und 17 Zoll. Die wichtigsten Entwicklungen gab es beim Prä-Unibody (Original), Unibody, Retina Display, Touchbar und SOC (system-on-a-chip) Design.
20011 Fragen Alle anzeigen
Frage geschlossen
MBP won't power on unless I remove the hard drive
I bought a macbook pro a1286 2010 model and was told it was probably a DC jack issue that caused the computer to not power on.
Just being curious I plugged it in and turned it on, and it worked just fine.
Then I installed a new hard drive and now it won't turn on.
So I replaced the DC jack, still it won't turn on
So I took the hard drive out, and it turns on fine.
That being said, I can't turn the computer off by simply holding down the power button. I have to unplug it for it to turn off
I've installed a new SATA cable to see if that was the issue, and still the computer only powers on without a hard drive installed.
What could be the issue here?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
what make and model is your HDD?
von
I've installed multiple just to rule out the hard drive
1 - seagate 320gb
2 - fujitsu 160gb model MHY2160BH
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It was a bad logic board
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
So basically you gave up on it.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 88
