Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
Earpiece speaker, vibration, microphone and home button don't work.
Just replaced the display assembly on iPhone 5c.
Took all the components from the old display assembly and put on the new one.
After this, earpiece speaker doesn't work, along with microphone, vibration and the home button.
I took everything off and put back on but doesn't work.
Perhaps I'm not fitting these components correctly?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I haven't actually tested the front facing camera yet to determine if it's the front facing cable assembly. I shall do that when I get the chance.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Ehh.. Possible that you haven't replaced things properly. Also possible that you've damaged some things, while doing the repair. It happens. Double check your work, see which things need attention
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
Well I managed to get the earpiece speaker working. But the front facing camera and proximity sensor still don't work. Also, vibration still doesn't work. Although, I've noticed it randomly crashing and the device feeling hot, so it's overhearing too.
von
Sounds like the front camera flex assembly is broken. There's a metal tab on the back of the shield plate, for the display assembly. It could be interfering with the vibrator motor. Your device is crashing and getting hot? I'm starting to wonder what parts of your logic board have been damaged...
von
Yeah thanks for the help. I got this off of eBay to fix and it was pretty much in pieces when it came. I'll check that tab to see if it's interfering with the vibration. It has got a compatible battery rather than an original, and only gets hot when charging. Perhaps that's it.
von
That could definitely be it. Third party battery over working the board
von
Antwort hinzufügen
August Williams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 301
