The difference between the size of an iPhone 6?
I was wondering the difference in size between an iPhone 6 and iPhone 6 Plus logic board
Ist dies eine gute Frage?
If you review the IFIXIT teardown's between the iPhone 6 & iPhone 6 Plus you'll see they are not shaped quite the same nor have the connections laid out quite the same. Yes, there are very similar! But, close only matters with horseshoes and bombs ;-}
iPhone 6 teardown look at Step 15
iPhone 6 Plus teardown look at Step 20
Anleitung
Schwierigkeitsgrad:
Mittel
Anleitung
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Good question. Just did a little research, and it being that I don't have a spare 6S logic board to measure. Here's what I grabbed
The forthcoming handset should also be 0.16mm taller and 0.13mm wider than its predecessor, likely to accommodate a new display assembly with integrated Force Touch sensors for sensing deep presses on the screen.
So even though the size is different the connects may still line up
No, the connectors are not the same. I guess I wasn't following, what Tom picked up right away. You can't swap the logic boards from one model iPhone to another. It simply won't work
if you want to put iphone 6 logic board into iphone 6 plus or the other way around, just forget it
Why would I forget it is the size different the processors are the same
Why is the processor even relevant?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 81
