Zum Hauptinhalt wechseln
Das DS Modell ist die siebte Generation der Spielekonsolen von Nintendo.
Why aren't the L&R buttons working?
I have an original DS. No Mods or anything ever done to it. The hinge is slightly damaged, but I doubt that's related. For some reason the L & R buttons are not responsive. On a rare occasion, one will work, but usually they don't.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This has happened to me with every model of DS I've owned and if it's like my problem it's just dust stuck under the shoulder buttons. I can usually get by with just blowing air under the L and R buttons. Replacement shoulder switches are available from some other websites but you have to solder. If you want to do that you should be able to just follow the steps in the back panel removal guide to access them. Then remove and replace.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
+ nice clear answer
von
Antwort hinzufügen
Jacob Sharf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 4,405
