My motherboard is causing my computer to shutdown every 30 minutes.
My motherboard is causing my computer to shutdown every 30 minutes.. It is not from any other hardware and has nothing to do with software. What can be causing this? Please help.
Ist dies eine gute Frage?
what type of motherboard and what makes you so sure its a motherboard issue are you getting any error messages. Mac or PC
von Jimfixer
It is a Z77. I have tried removing all the hardware (except power supply and RAM) and the problem continued. It is a PC. No I am not getting any error messages. Windows.
von Mert YILMAZ
AS Rock LGA1155 DDR3 SATA3 USB3.0 Quad CrossFireX and Quad SLI A GbE ATX Motherboard Z77 EXTREME4 http://www.amazon.com/LGA1155-CrossFireX...
von mayer
Is it overheating? What indicator lights do you get when it powers down? How long before you can restart?
von mayer
If you know it isn't the software or other hardware, you should have the answer already. I would still suspect other hardware such as the cpu cooling fan. If it has stopped or is not running at proper speed or there's a lot of dust in the heat sink, that could cause the system to shut down.
von emplehod
