Zum Hauptinhalt wechseln
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
99 Fragen Alle anzeigen
How to recover Internal Storage (Unit split in to two)
Hello,
My Zenfone 2 ZE550ML was split into two, is there a way to retrieve the internal storage of the unit? Does anyone knows where it is located?
The unit was severely destroyed however I am quite sure that the camera and other parts are still good.
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Any updates? Have you tried taking the phone apart?
von
I believe the motherboard is still fine.
Are there any other tool needed for me to connect the motherboard to my PC?
Appreciate your help. ;)
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The only way you will be able to retrieve your data is to move the mother board into another identical phone or repair the one you have enough to connect it to a computer and retrieve your data that way. if the mother board is damaged to bad then all is lost
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
it's possible connect to pc (cable usb?) the memory into the motherboard ?
von
only if you can power the original motherboard which is basically fixing the phone
von
Well, if it split into to and missed the motherboard(only in the upper portion of the phone) then getting a donor phone would be a good way of retrieving data.
Can you upload images of the phone?
Bewertung 2
Antwort hinzufügen
Jr Chupungco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 254
