Zum Hauptinhalt wechseln
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
198 Fragen Alle anzeigen
TV Screen Won't Turn On, Sound Still Works
I bought an LED tv awhile back, unfortunately the screen was scratched the day I bought it but was on a deal so I had to get it. Had it for a couple years, approximately 3, and then I gave it to my mom. She had it for a good while and then the screen went black recently but the sound still worked so I'm trying to help her fix it. I know a little about technology so I can narrow it down to a few things I think might be wrong with it which would either be the capacitors, the backlight, or transmitter I believe. I'll update with more information later. This is all I know at the moment, we're states away and I have a busy schedule so it takes time for me to get in touch with her. So if anyone can help please stay tuned, thank you.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
if the back-lite is on then this is most likely a tcon issue.
if the panel is dark no backlite then this could be a few things
1st if no backlite dark panel disconnect the wire harness between the main board and power supply. Now plug the set in...that should force the backlite on---if it does not come on the you have either a panel or power supply isse
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
KP wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 566
