Zum Hauptinhalt wechseln
Apple brachte das verschlankte und aufpolierte iPad Air am 1. November 2013 in den Versionen Space Grau und Silber auf den Markt. Es beinhaltet den A7 Prozessor und kann mit 16, 32, 64 oder 128 GB Speicherkapazität gewählt werden.
577 Fragen Alle anzeigen
iPad Air Screen Broken into THOUSANDS of bits
Will the replacement instructions work if my screen is pulverized into thousands of pieces? It doesn't seem I'll be able to pry and suction cup anything. Would there be alternative instructions?
I'm looking at repair instructions for "iPad Air Wi-Fi Front Panel Assembly Replacement" by Author: Sam Lionheart. iPad Air Wi-Fi Frontglas austauschen
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
First have a good working area because that glass is going to get everywhere. If you don't have experience repairing iPads stay away from the metal tools, because you will go in to far and cause damage to the LCD. Use lots of heat and plastic tools or even playing cards. Those severely broken screen are a pain but go slow and lots of heat.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you! I like the playing card suggestion
von
Hilfreichste Antwort
Yeah it will work. You will need to get something like an iSeasmo tool to get inbetween the frame and glass. You might also scratch the metal frame(probably screwed up anyway).
Please make sure your LCD screen still works fine, because otherwise you will need to replace the entire display and glass digitizer.
Bewertung 2
1 Kommentar:
Jake, thanks. Oddly, the LCD look fine thru the haze of broken glass. I will look for the tool you suggested.
von
I successfully completed my repair, today. It really wasn't too difficult. Managing and removing pulverized glass was the most tedious part. Both Jake's and DC LifeTech's suggestions were helpful... lot's of heat, glass safety measures and a strong device for cleaning glass from the edges... I used a very good sharp pen knife (I'm an olde-timer!)
Due to extensive glass pulverization... the center of the broken glass was removed 'close' to the edges. Then, I slowly removed the remaining glass from the edges with lot's of heat.
The kit I purchased (iPad Air Front Glass/Digitizer Touch Panel Full Assembly ) had a new home bottom. So, I didn't need to be careful to conserve the old one.
I did the repair while pleasantly listening on radio to Martin Brodeur’s no. 30 being retired... raised to rafters at "The Rock" (Prudential Center) .... the whole ceremony... and, part of the subsequent match with the Edmonton Oilers....
Bewertung 2
2 Kommentare:
Glad to here it! Fixing is an amazing thing to do, congrats!
von
Antwort hinzufügen
negocios0rsk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 211
