Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Vom Mercedes Typ W123 gab es verschiedene Modelle wie 240D, 300D, 300TD, 280E und mehr. Es handelt sich um Limousinen, Coupés und Kombifahrzeuge aus den Jahren 1977 bis 1985.
127 Fragen Alle anzeigen
need part name by gas door
i have a 300 diesel but i need to replace the plug that keeps the diesel in i dont know the name of it it is a rubber thing like a plug by the gas tank that keeps it from leaking out its in the gas door to the left of the fueling hole any help i need so i can order this and get rid of the ugly gas spot and make my car newer again
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Can you provide a picture of the part you are referring to.
von
Einen Kommentar hinzufügen
Das Essential Toolkit
Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
Jetzt kaufen
Jetzt kaufen
1 Antwort
Hilfreichste Antwort
Hello, are you referring to the hole shown to the left of the gas fill opening in this picture? With the red box around it.
If so that is there on purpose. It is a drain hole. Mainly, it is to let water drain out since the gas door is not sealed. But the other purpose is to let any fuel spilled or leaking from the gas cap/fill opening to run out of the drain instead of pooling up and running down the side of the car. This hole should not be plugged up.
If there is fuel leaking on the ground, going through this hole and down the drain hose, then the hole is not the problem. The problem is the fuel getting to the hole!
One very likely cause is that you may have a leaky gas cap. Consider replacing the gas cap seal as shown here:
Mercedes W123 Verschlussdichtungen vo Treibstoff und Öl auswechseln
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
tracy smith wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 109
