Furby Boom's not moving much and goes to sleep after 1 minute
My daughter's Furby just started to make this cracking noise with every word it says. Also the Furby's moving very quietly and not moving back and forward (at all).
Usually when the Furby goes to sleep, it will bend forward. Also the its ears (sometimes) are not moving forward when going to sleep.
When the Furby is awake, it will last like 1 minute and its eyes will light off (and will go to sleep). It will only wake up if I shake it well.
I also noticed that will not react fast/properly when touching him.
The reset (or the change of personality mode which only went right once) won't help.
I kindly ask for help. I also speak Dutch, Spanish and Italian.
Thanx!
Ist dies eine gute Frage?
11 Kommentare
I have the same problem.
von ozzie
Have you solved the problem so far? I haven't yet.
von Ciro Morante
I am having this issue too. I skinned Furby, safely without scissors like I see many using, I found out the Furby I bought used had an issue. His red wire which is attached to his tummy had come out of its socket and there was pieces of the wire still in it. Furby does not move his stomach, ears, mouth or eyes for me and powers down after a few short seconds. Fresh batteries were not the issue as the ones I used were brand new and worked in other devices. If someone can solve this problem I will be eternally grateful to get my pink, orange and blue Furby Boom up and running again.
von nickheartsbecca
Hi, i have the same problem and i tried also refresh button and new batteries..it is still the same, Do you have some contact to service? thanks
von Julia Juliana
same here!! I got 1 furby to work, but the other, Thunderstruck, keep doing this.
von belinda_mcconnell
6 weitere Kommentare anzeigen
