Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
Frage geschlossen
iPhone 5C doesn't increase battery percentage?
Hi everyone.
I have a problem with my iPhone 5C.
I bought it from a friend of mine, that told me that the smartphone had many issues.
Mainly the problems was the 3.5 jack, that didn't work.
Given that I am able to repair smartphones, I decided to buy a new lightning dock for my iPhone.
After I changed it with the old one, the new jack seemed to work.
Connecting the lightning cable, the smartphone charges the battery.
But 5 minutes later I found out that the battery percentage wasn't increasing.
This fact scared me a lot, because I know that this kind of issue is due to a broken IC near the battery connector (on iPhone 5). So, I remounted the old dock to exclude any damage to the logic board. Fortunately the iPhone started charging the battery normally, but the issue with jack still remains.
I doubted that the component I ordered on eBay was broken, so I tried with another new one. Nothing to do, same story, another day.
Can this be caused by the fact that the components on eBay aren't original?
Thanks in advance,
Roberto.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I am pretty sure the U2 IC chip is what the phone using to communicate with the battery and charging port.
It is a common repair for iPhone 5s and 5Ss since they break a lot.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Ok, but why this issue happen only with other lightning docks?
With the original one it works perfectly (excluding the jack).
von
Try getting another replacement part. If the U2 chip is not the problem, then it is probably a bad charging port. I bought an iFixit one and it works like a charm.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 76
