How much does it take to buy a new screen 3ds
I sat on my ds how much does it take to replace a screen
Update (02/18/2016)
Ist dies eine gute Frage?
Depending on which screen you broke and how ambitious you are the screen repair tutorial is here Nintendo 3DS XL Touchscreen Austausch
and the replacements for them are here
[verlinktes Produkt fehlt oder ist deaktiviert: IF258-025]
Hope this helps
War diese Antwort hilfreich?
Upper screen
so then you can purchase the screen for about 25 dollars and follow the guide in the answer above to fix it. If you want someone to do it for you then you should check your area for repair services near you
So I took apart the bottom and replaced the screen but now my select button does not work
You may want to take it apart again to check the connections on the buttons. something could have come apart when you were putting it back together
ok thanks for that I will check
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,720
