Zum Hauptinhalt wechseln
3,28-Megapixel-Camcorder, der im März 2014 veröffentlicht wurde. Identifizierbar über die Teilenummer 9176b001.
Water Vapor on the camera lens.
I took my camcorder outside and it stared raining. Now whenever I use my camera the lens is foggy and I'm not able to see clearly on the device. Did me taking my camera outside permanently damage my camera? If not how can I fix this problem?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Water entering your camera can leave smudges on the interior of your lens that you can not clean. Do not attempt to use a hair dryer to dry your camera. You can try placing your camera in a bag of rice to see if this resolves your problem.
War diese Antwort hilfreich?
Bewertung 1
id reccomend taking the thing appart, and try to clean the lens, it could also be (if your device has optical focus (identifyable by faint clicking noises when it focusus) and water coming in there, and leaving ressidue in the mechanism, this can be fixed by washing yoour immage sensor in 96% alcohol in a super clean container, and let it dry out (make shure to not add any impuritys to the alcohol like water or using a container with impuritys in it
Bewertung 1
Antwort hinzufügen
Deion Woods wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 612
