The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
235 Fragen Alle anzeigen
How can I fix my xbox 360 red dot?
My Xbox 360 slim powers on fix, would play for 10 to 15 minutes then green dot would turn red and d screen would go blank, light on the power supply turns from green to orange. When turned off for 2 to 3 hours, turns back on works for 10 to 15 minutes then red dot appears again. Please can someone help me???
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Punktzahl 0
Einen Kommentar hinzufügen
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
2 Antworten
Gewählte Lösung
Hi,
Red dot, means "fatal failure", The Xbox is indeed a "PC" inside a "box", If you want to fix that you have to open the machine and clean ALL the ventilation holes, after that change the "cooler heat pasta", because Im almost sure is "DRY", after that you can play 24/7. ;)
Regards.
Luis.
War diese Antwort hilfreich?
Punktzahl 0
Thanks a lot, am give it a try an see what happens. One last question, which cooler heat pasta would you recommend arctic silva 5 or arctic cooling mx-4
Punktzahl 0
Antwort hinzufügen
verol fraser wird auf ewig dankbar sein.
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 169
