Zum Hauptinhalt wechseln
Model A1199 / mit 2, 4, oder 8 GB Kapazität
80 Fragen Alle anzeigen
Not charging or syncing via USB, charges via Firewire
Recently acquired this as 'non-working.' Battery was completely drained. Plugging in to USB, it briefly shows as charging, then reverts to not charging, but apparently able to run off the power provided by USB. It also doesn't show up as a disk or in iTunes.
A firewire connection will provide the 'not supported' screen, but allow it to charge.
There have been some similar problems reported here that suggest a bad battery may cause behavior like this, but none seem to indicate that this is actually the solution. So is it a battery issue, or is the USB on this toast?
Ist dies eine gute Frage?
Bewertung -1
Kommentare:
I have the same problem on 2 ipods, power up via firewire but can't get them to recognize in itunes or charge via usb.
Already replaced battery and use genuine apple usb cable. I'm out of ideas to solve this :(
von
Sorry, looks like no one saw your question as it was tacked on to someone else. This is why we ask that people start their own questions.
von
same problem here...i have already changed the baterry and tried many usb cables but still nothing (work fine but can not connect to pc). its gegining to irritate me :( any ideas? thx
von
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I would replace the USB cable with a high quality one. I've seen this a lot, and the cheap USB cables just don't work correctly.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
The same USB cable works fine with multiple other units. So cable is fine.
von
Mayer is on the right track, if it isn't the USB cable itself, then start with the battery replacement. Bad batteries do cause peculiar behavior
von
I've actually seen on a few iPods and one first gen iPhone I have where the USB controller on the board goes out. Only way to fix is a new board in that case.
Bewertung 0
Kommentare:
How can I identify the USB controller? I might be able to replace it with proper equipment.
von
Antwort hinzufügen
mgb2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,173
