Zum Hauptinhalt wechseln
The Canon EOS 300D is a 6.3-megapixel entry-level digital single-lens reflex camera.
20 Fragen Alle anzeigen
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
War diese Antwort hilfreich?
Bewertung 0
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Bewertung 0
This can also be caused by a defective/broken CF door switch
Bewertung 0
Could it be for any other situations, as I have done all checks and keep the problem.
Bewertung 0
Antwort hinzufügen
Rob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,666
