Zum Hauptinhalt wechseln
The Motorola Lapdock 100, manufactured by Motorola in 2011, was created to adapt to the smartphone for easier use for typing and surfing the web.
7 Fragen Alle anzeigen
Why is my trackpad being jumpy and at times unresponsive?
Every time I try to navigate with my cursor, it does not function smoothly or correctly.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Can you try using a USB mouse and see if the problem goes away? I'm trying to narrow down hardware versus software.
Also, a quick trip to the mouse control panel, you should be able to adjust the Touch pressure, make it require less effort to make contact with the trackpad.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I cannot find a decent teardown.. Is there a swollen battery under the trackpad?
von
The lapdock 100 has the same segmented battery approach found in the 13 inch retina, except that they're flatter, and there are only three of them; it's a sound theory you have there.
von
Your sensors are dirty , get to the sensor and clean it with a damp Qtip. Common problem not a big deal
Update (02/25/2016)
Belay my last answer I didn't realize it was on a laptop. Late.
I would try and erase the driver for it and reload it. Pretty possible the driver has gotten corrupted other wise just plug in a wireless one
Bewertung 0
refer to this site Motorola Lapdock 100 Trackpad Replacement
Bewertung -2
1 Kommentar:
"Forbidden Access" please do not post a link that can not be opened,
von
Antwort hinzufügen
Jessica wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 172
