Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
Keyboard glitches out and trackpad doesn't work
Hi,
I am having some issues with my MBPr, The trackpad all of a sudden stopped working and the keyboard glitches out. I restored the computer to factory default, it did not help. Is the issue most likely the keyboard connector and trackpad connector disconnected or could it be that the whole top case was ruined somehow?
Thanks,
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Check it for a swollen battery.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
And you tell me to explain the problem even more and put links and stuff yet look at your answer
von
The irony here makes me smirk. :)
von
Expanding on @Mayer's answer, there's a valid chance that it's a swollen battery, or a faulty Trackpad.
CoconutBattery 3.3 is the current version, and it's a good tool for assessing battery problems.
http://www.coconut-flavour.com/coconutba...
iFixit's Guide to 2014 Retina Battery Removal:
MacBook Pro 13" Retina Display Mitte 2014 Akku austauschen
First, use that program and see if "Service battery" or anything other than Good is listed. Design Capacity should be high, too.
Second, as a diagnostic, open your retina and loosen the battery screws as much as you can, relieving any pressure from a swollen battery, and see if the trackpad gains some sanity. If it does, time for a new battery. If it doesn't, it's a trackpad.
Bewertung 2
2 Kommentare:
Obviously I'm going to have to do a guide on how to get this battery out in a quarter of the time the iFixit staff does it.
von
that's why we're here, right? :D
PS, I voted your answer as helpful; though short, it was the best concept.
von
Antwort hinzufügen
Masoud Harati wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 417
