Zum Hauptinhalt wechseln
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 Fragen Alle anzeigen
rapid power loss power dives from 100% to 3% in seconds
the power reading reduces from 100% to " critical battery power" in about 10 seconds after take off any advice . tried two new batteries same result. Charger charges back up to green within 15 mins. switch off copter and reboot shows the power at a level you would expect (80-90%) than does the same again when you you press take off. any advice ANYONE cheers
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Try a different charger and measure the battery voltage if you have a multimeter.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
colin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 88
