Zum Hauptinhalt wechseln
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
Why isn't my device turning on?
I've held down the power button and it isn't turning on, no matter how long I hold the button down for.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
Hey, my 4 year old sister LeapsterGS won't turn on. I've tried doing new batteries it still won't work can you please help or do you know something about it??? AND, I've lost the charger that came with it... Thanks!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I'd start by making sure the battery is charged. Try plugging it in using the adapter and cord. Be sure that you double check the connections between the adapter and the wall and the cord and the device. Make sure that they are both connected securely or the device will not charge and this is a common mistake.
If the LeapPad still won't turn on, it could be that the battery is dead. At that point in time, all you can do is replace the battery.
It could also be a malfunction with the power button or an issue with the software, but I'd make sure it's not the battery before anything else.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
How old is it? Is it still under warranty. Are you sure the battery is charged up? Do you get anything on the screen? http://www.leapfrog.com/en-us/legal/warr...
Bewertung 2
Try New Batteries!
Or charge it with the charger that came with it!
Bewertung 0
Antwort hinzufügen
David Saso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 139
Insgesamt: 15,065
