Zum Hauptinhalt wechseln
Der Canon Selphy CP910 ist ein kompakter Drucker, der über eine WLAN-Verbindung mit einer Kamera, einem Computer oder einem Mobilgerät verbunden werden kann. Er ist die 34. Generation der Selphy-Druckerserie von Canon.
Printer still indicate low ink?
After replacing new ink cartridge, the printer still indicate low ink?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 20
3 Kommentare
I had the same issue with my CP1200. The solution was exactly like with the CP910 described here
von
Just confirmed that this also applies to the Selphy CP1200 which Martin Merz previously confirmed...
The exact same gear in the exact same location..
When that little gear started to move over, pictures were starting to print out with some yellowing on the right side. This would slowly progress to the middle of the print.
Once that yellowing hit the middle of the print, then the printer would no longer detect a replacement print cartridge.
One little note to mention: When attempting this fix, slide that little gear only part way back, just a smidgen back. Use a very small dab of superglue on the very tip of a toothpick to just apply a miniscule amount of Super Glue to the shaft.. Then slide the gear back over the Super Glue all the way back to it's original position. This way you won't accidentally super glue gears to each other..
von
This worked for me for awhile, but then the low ink message started coming back. I opened it back up thinking the gear slipped again, but it was still secured in place with the glue. I ended up scraping the printer and getting a newer model. Hopefully won’t have this issue in the future.
von
Einen Kommentar hinzufügen
11 Antworten
Gewählte Lösung
there is a little gear which can get out from it place in time. Check its position and if its moved - use a glue to hold it at place.
here is an example of wrong position of the gear:
If you can't figure out where is the gear in a printer - look at the bottom right corner of the picture:
If you need a replacement part:
  • google tne next text "pinion gear 10T 0.3M bore 1.5mm";
  • also spare parts for RC helicopters can be applied, for example MH-BP031015
War diese Antwort hilfreich?
Bewertung 28
36 Kommentare:
You are a genius. Thanks a million!! Zach
von
Thanks! My wife now thinks I can fix anything. Made my day.
von
Thanks Alexander! That was it!
von
how do you get to the gear?
von
Thanks for that
von
31 weitere Kommentare anzeigen
I solved this problem but printer stiil give the same message. Any ideea?
Many thanks!
Bewertung 1
Bewertung 1
Hey! I tried it on some older models (CP760 and 2x CP780). They also have this problem. Moving gear into place fixed it
Bewertung 1
2 Kommentare:
Hi, quick question, what is the teeth count on CP760, because my was disintegrated. Thanks
von
I just checked it the gear has 10 teeth on the CP760. Now I'm going to check if this will fix my issue as well :-)
von
Someone abandoned their CP910 because of the gear failure. I ended up getting it so I could try fixing it.
I initially slipped the gear back into place but didn't have super glue handy, so I just used it and it worked for about 8 prints before having problems again. I had superglue this time, and made sure the gear was very secure. Did 6 prints in a row and they all printed great.
There is a Youtube video that shows how to do this, but I've since realized that unlike the video, it's better to undo the three screws holding the main print engine assembly and remove it from the enclosure first after disconnecting the 2-pin fan cable. It's easier to work that way.
Bewertung 1
Done! The gear was still there but it was almost totally off the shaft. I applied a small dab of Gorilla glue in the gear and pressed it back on. And now I have a printer again!
Bewertung 0
Awesome! Stuck some gaffa tape to the metal on the far side - good for now!
Bewertung 0
1 Kommentar:
Thanks so much. You are a genius. It’s working well now
von
Thank you! Worked for me as well for a newer model CP-1200 !
Bewertung 0
Amazing, and it works. To Canon's credit the opening and access to the printer's innards is easy and commendably simple. It is a shame that their engineers did not think to put the same thread lock paste they used for the screws securing the mechanism to the enclosure. Many thanks for giving a 12 year-old CP910 a new lease of life!
Bewertung 0
1 Kommentar:
How do you get to the innards ??
von
Just one quick comment regarding CP-800 modells.
There are two different versions of gear existing !
One with 10 tooth, one with 11 tooth. Ensure to pick the right one :)
Don´t know if this is valid also for other versions...
Bewertung 0
works!!! 100%
thank You
Bewertung 0
Antwort hinzufügen
Noorhaili wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 67
Letzte 30 Tage: 338
Insgesamt: 47,255
