Zum Hauptinhalt wechseln
Das Samsung Galaxy S5 mini ist ein Smartphone erschien am 28. Juli 2014. Es ist mit einer 8MP Rückkamera, einem 720p Display, einem Fingerabdruckscanner und einem wasserdichten Gehäuse ausgestattet. Es hat ein größeres Display, längere Akkulaufzeit und eine bessere Kamera als sein älterer Bruder, das Galaxy S4 Mini.
30 Fragen Alle anzeigen
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
von
πως το διορθωνουμε αυτο το ποβλημα?
von
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
Bewertung 1
2 Kommentare:
how do i fix this problem?
von
by flashing it with Odin
von
Antwort hinzufügen
tonyknors wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 1,761
