Keeps restarting after screen replacment
I replaced cracked screen on my T83 TELSTRA DAVE 4G and the screen works, it just keeps restarting itself, loads up with the android man then restarts itself constantly
Ist dies eine gute Frage?
"Hi, Wondering if the new screen - is it OEM (original equipment manufacturer) i.e. same maker/same part number/serial number (if any) on back of screen or a 'compatible' part? Either way I think that you have proved it to be the problem If OEM it may be faulty, if 'compatible generic make' it may not be compatible. Go for a return as faulty or not compatible with this model"
by jayeff
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 113
11 Kommentare
hi, Have you tried a hard reset?
von jayeff
Hey there yep power button plus up/down buttons doesnt seem to work
von wisemonk
Hi, Sorry if i'm being a bit pedantic. Did you press and hold the Vol+ button before you pressed the power button, (then holding them together)? Also did you try removing the battery for 1-2 minutes, reinstalling it and then trying a reset?
von jayeff
I tried pushing all 3 at once, once i sometimes do that the red light just stays on
von wisemonk
Hi, What happens if it is 'off' and you just connect the charger?
von jayeff
6 weitere Kommentare anzeigen
