Tablet has a pink screen, how can I fix this problem?
Tablet has a pink bach ground screen, I have already reset to factory settings and it didn't fix the problem. What can I do to fix this problem?
Ist dies eine gute Frage?
This is generally a failing display or digitizer, Replace it.
Here's how to do it: https://www.youtube.com/watch?v=7N9--kUh...
War diese Antwort hilfreich?
Sometimes the graphics cable gets dislodged
Prise open the back
Black flat cable to the right
Check line on the cable lines up with board line
A wiggle and a push helps the cable in
Put some tape across connector to prevent further dislodgement
Hope this helps
Paul
Will this break my tablet
Can my tablet be fix some other way I don't want to brake my tablet
My whole screen is pink and that only thing I see on my tablet what causes this
Tablet has been dropped or not correctly reassembled after battery install
Could it be that it was expose to sun to long
Possible in hot climate while tablet is runing causing failing display or digitizer, Replace it.
Thanks Paul, you were spot on.
No I didn't drop it
I removed the connector, cleaned it off , and put it on again. And now are all the colors there again!
Thank's a lot!
Best regards Erland
Worked for me. Try it again.
I did everything you say do but it's not working
I cant do that my parents say I caused the pink screen when I was only watching something in blue screen. Filter and for some random reason the screen turned pink
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 56
Insgesamt: 21,388
2 Kommentare
What can I do to fix my color screen tab
von pejo edwin
Had this in the back of my head, visited a friend and her Galaxy Tab was pink. Had a think and Tadaa, opened it up as directed, removed, cleaned, replaced flat cable, all fixed. Cheers
von cybergod7
