Zum Hauptinhalt wechseln
Das Sony Xperia Z5 ist ausgestattet mit einem 5,2 Zoll 1080 x 1920 Pixels Display, hat einen Qualcomm Snapdragon 810 Prozessor, dazu eine 3GB RAM sowie eine 23 MP Rückkamera.
69 Fragen Alle anzeigen
How to replace the frosted glass back?
I dropped my z5 dual straight on its back and the frosted back glass has shattered. If I buy the replacement part how would I go about replacing it?
Ist dies eine gute Frage?
Bewertung 2
Kommentare:
Here is the video showing how to replace broken z5 back cover:
https://www.youtube.com/watch?v=FY2z27SA...
by
Einen Kommentar hinzufügen
Android Fix Kits
Ein neues Display oder Akku sind nur ein Kit entfernt.
Jetzt kaufen
Android Fix Kits
Jetzt kaufen
2 Antworten
Hilfreichste Antwort
You should check the model number first if this is a dual sim version?
You can check the model number of the Sony Xperia by using this:
You can buy the back cover from here: (It fits Sony Xperia Z5 E6603 E6653 E6633 E6683)
http://www.ebay.com.au/itm/Original-Glas...
Here's the guide on how to do it: Note that you only need to do step 1 and step 2.
Sony Xperia Z5 LCD Bildschirm ersetzen
Note: Please be careful because if I'm correct there may be a white NFC sticker tag on the back cover (It is a white sticker with two golden contact points). This model probably doesn't have it. If it does, you'll need to heat it up then carefully separate it from the back cover as it is held by adhesive.
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
No backlight in Sony xperia z3 compact. Solución please
by
I did all those steps now nfc doesn't work. Maybe sticker not making contact with the motherboard. Do I need to buy a new sticker? And if I open the back cover again, will it remove all the glue, needing a new cover?
Bewertung 0
Antwort hinzufügen
Karthik Krishnan wird auf ewig dankbar sein.
Statistik anzeigen:
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 31
Insgesamt: 20,197
