Zum Hauptinhalt wechseln
Released on June 23, 1996, Model NUS-001, the N64 is Nintendo's first, and, up until the release of the Switch, only 64-bit gaming console (The GameCube, Wii, and Wii U could perform 64-bit floating-point calculations, but this is not true 64-bit architecture).
New to N64, it turns on but no console noise no picture?
I've recently bought the Japanese orange pikachu N64 and when I turn it on the cheeks flash and then stay on but the console makes no noise and no picture comes through either the rf cable or the rca from my gamecube, any advice?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Thanks, I will try that :)
von
Einen Kommentar hinzufügen
3 Antworten
You most likely need to clean the cartridge slot. If the N64 can't read the cartridge, it will not display any picture or sound. I usually clean my older cartridge-based Nintendo systems by dipping a qtip in %90 isopropyl alcohol (rubbing alcohol) and then running the qtip along the connector on any N64 game cartridge. Then repeatedly insert and remove the cartridge from the slot on the system. This will clean off any dust or dirt that has built up inside the slot over the years.
War diese Antwort hilfreich?
Bewertung 0
not an expert but try to unplug and plug in the AV or RF cable, if it doesn't work, get 3rd party cords, happens all the time to me
Bewertung 0
I know. You slap the bottom hard 2 times. Then you chuck it at the ground. It should work by then.
Copyright: how to basic
Bewertung 0
1 Kommentar:
Ps.
it actually worked
von
Antwort hinzufügen
Tom Jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 4,054
