HP bought out Compaq so HP has the following for BIOS:
http://support.hp.com/us-en/product/Comp...
The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps for modifying the boot order may vary depending on the model of the computer.
note:
BIOS configurations vary depending on the computer. For further information on a specific computer, refer to the documentation provided with the computer or go to the HP Drivers and Downloads page. The BIOS settings are generally listed in the Maintenance and Service Guide.
Follow the steps below to configure the boot order on most computers.
Turn on or restart the computer.
While the display is blank, press the f10 key to enter the BIOS settings menu.
note:
The BIOS settings menu is accessible by pressing the f2 or the f6 key on some computers.
Select the Advanced tab using the right and left arrow keys.
Use the up and down arrow keys to select Boot Order.
Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings
To reset the boot order to the default settings, follow the steps below.
Press the f9 key to reset the BIOS to the default settings.
Press the f10 key to save the changes and exit the BIOS settings menu.
note:
BIOS configurations vary depending on the computer. For further information on a specific computer, view the documentation provided with the computer. The BIOS settings are generally found in the Maintenance and Service Guide.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
