Why won't my console sync button work?
Over time my sync button on the left side if my console worked but now it's gone. When I press the button on the left side it makes a ding noise but the console symbol suppose to blink indicates in trying to sync. My controllers work when I press it but not the console button. I have to play with my controllers wired but I really need help with this to have it fixed. I tried hard reset and everything so I assume its an issue inside the console.
Ist dies eine gute Frage?
33 Kommentare
whats a soft power down
von Caylon Grabenhofer
Wow! I read this wrong by the slightest bit, tried it again but this time unplugged the usb from the Xbox as well, even tho it’s a loose chord I didn’t understand that it needed to be removed
von Gavin
ty this worked the controller i bought from gamestop has a broken syc button thought i was gonna have to drive 29 miles to return it so much for the tested sticker n the package
von grywlf_26
Even if the sync button never works again, plug the controller in using an android charging cable if you don't have the one specifically for the xbox. Once its plugged in, turn controller on and press the controllers sync button. The controller will sync to the xbox. Then unplug the controller and you'll be good to go. Just went through this nonsense 5min ago. I had to do it again once powering off the Xbox and turning it back on but small price to pay.
von D. Darko
Thank you bro you're a lifesaver!!!!
von Zach Vance
28 weitere Kommentare anzeigen
