Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Introduced in 1985 to bring style, performance, and luxury to a mid-sized vehicle. This model is legendary for reliability and longevity, with many still on the road decades after production ended.
3 Fragen Alle anzeigen
changing alternator belt what do I have to do
change alternator belt on 740 volvo
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Quote from http://www.justanswer.com/volvo/1tkgd-ch...
Mike, volvo Tech
to change the alternator belt at the bottom of the alternator at the front is a 13mm nut, loosen it some, on the side at left side of the alternator at the bottom there is a 10mm bolt loosen it and the belt will slacken. the a/c compressor has a a 13mm nut on the front top and a 13mm nut on the top back brackets, once they are loosened loosen the 10mm bolt on the side till you can get the belt off then remove the alternator belt.
reinstall the belts tighten the 10mm bolt till the alternator belt is tight, then the 13mm nut. tighten the 10mm bolt on the a/c compressor till the belt is tight then tighten the rear 13mm nut and then the front 13mm nut
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
william thornton wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 229
