Zum Hauptinhalt wechseln
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
38 Fragen Alle anzeigen
Clean light still blinking 7 times after I installed a new element
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Not sure what to do now?
Any help will be appreciated.
Thanks
Chris
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I have the same issue - once it was replaced, it is heating the water but after the rinse the light will flash again 7 times. I have reset but still have the. BLinking light
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The flashing "clean light" indicates, a water temperature, heating problem.
It could be due to, a bad heater element, thermostat, or a control board.
Most of the time, it's due to a low water temperature.
You need to make sure, the water temperature, in the bottom of the tub, on the first fill of a wash cycle, is at least 120 to 130 dgrs. F. (you should be able to run the hot water faucet at the kitchen sink, and get somewhere in that range, before you start the dishwasher).
Read more: http://forum.appliancepartspros.com/dish...
http://www.appliancepartspros.com
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
chrisandhelene wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 61
Letzten 30 Tage: 405
Insgesamt: 12,371
