Zum Hauptinhalt wechseln
The Sony VAIO VPCF132FXB is a mid-grade laptop designed for multimedia and personal entertainment use. It features an Intel Core i7 processor (1.73GHz) and an integrated NVIDIA GeForce 310M GPU (512MB onboard memory).
3 Fragen Alle anzeigen
Laptop works without battery, but does not power on with battery
I bought a new battery for this laptop, but it still does not power on. If I take the battery out, and plug the laptop in for power, it works fine. If I put the battery in, and try to power it on, it does not power on. Any ideas on what might be the problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I found a issue with the batteries and apparently there is incompatibles with certain batteries. You should call Sony representatives and determine if that battery you got is compatible or not.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks. I will check that out.
von
Antwort hinzufügen
casaresjb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 165
