Zum Hauptinhalt wechseln
The TI-30X IIS is a scientific calculator with trigonometric functions first introduced by Texas Instruments in 1993. It uses both a battery and a solar cell for power.
Automatically adds a digit to the end of my entry
My calculator automatically adds a 9 to my last number every time I try to do math. For example, I type 5 + 6 and expect =11, but calculator does 5 + 69 and I get =74 :(
The 9 button does not appear to be sticky.
Ist dies eine gute Frage?
Bewertung 7
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Technical support just helped me fix the same issue. You need to reset the calculator. Press the "2nd" key followed by "0". Arrow down to option 2 "yes". Problem fixed.
War diese Antwort hilfreich?
Bewertung 18
10 Kommentare:
worked for me ty
von
This worked for me thanks so much
von
Mahalo! That worked for me, too.
von
OMG! I can't believe it was that easy to fix. Thank you very much!
von
mine kept adding 0.5, and this just fixed it, thanks so much!!
von
5 weitere Kommentare anzeigen
One of my calculators is adding a digit to the end of each entry.
I know how to reset the calculator but when I try, I am unable to arrow over to Y on this screen:
RESET: N Y
I also tried holding down ON and CLEAR at the same time but that is not working to reset the calculator either.
Bewertung 1
2 Kommentare:
thank you so much
von
You are a legend
von
shorted PCB keys, try to clean the PCB keys with alcohol (To dismantle, you'll need to apply hot air on the boss around 200°C)
Bewertung 0
Does anyone know how to do this on purpose?
Bewertung 0
1 Kommentar:
I’m also curious about how to make this happen on purpose. Thanks for the solution by the way, real life-saver
von
0.5 2nd and the arrow
Bewertung 0
If you notice there is a small k on the bottom right. The constant. Here is information about it and how to set it. I can be used for "good" not "evil" For example: If you are doing a process over and over like # X 2 + 3. You can store the operations as k, then just put in the number and hit =. If you put in a 9 and hit =. It would show 9 X 2 + 3 = 21. Or maybe just X 2. Old calculators, you could hit the = to keep doing the same thing like X 2, X 2, .... This is what the k does.
How do I use the constant K function on the TI-30X IIS/B?
On the TI-30X IIS/B, pressing [2nd] [Division] turns on the constant mode and allows the user to define a constant. K appears in the top of the display when the constant mode is on. The [=] key places the contents of K at the end of the expression in the display.
To enter a constant:
1) Press [2nd] [Division]. If a constant is already stored, press [CLEAR] to clear it.
2) Enter a constant (any set of operations, functions, and values).
3) Press [=] to turn on the constant mode. K appears in the display.
4) Press [CLEAR] to clear the display.
5) Enter an initial value. If a value is not entered, 0 is assumed, and "Ans" will appear in the display.
6) Press [=] to place the contents of K at the end of the expression and evaluate it.
7) Continue pressing [=] to repeat the constant.
The result is stored in "Ans", which is displayed, and the constant is used to evaluate the new expression.
Please see the TI-30X IIS/B guidebooksfor additional information.
Bewertung 0
Antwort hinzufügen
Michelle Leonard wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 49
Letzte 30 Tage: 144
Insgesamt: 16,428
