CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a “dead” keypad/console)
indicates one or more key switch lines are stuck or shorted on either the control or the keypad.
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control’s response:
➔If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
➔If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
14
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
5 Kommentare
My quiet partner I, stop working, START AND CANCEL/DRAIN button won’t light on(work). opened the console, found that green ribbon has two line broken, tried to use thin copper wire to connect the broken point, but cancel/drain light is always on, any suggestion?
von Ben K
I tried all the buttons on the front panel after trying the heat dry button suggested for weeks.... when I finally was giving up and decided I couldn't break what was already broken to open the panel ... my phillips screwdriver didn't work so I took the handle and started lightly tapping across the top of the panel and the light went off immediately. I opened the door closed it again and it allowed me to start a wash cycle... praise the LORD... Oh I forgot to mention I prayed over it....
von Linda Whetstone
Normal button flashing and heat dry will not go on. Press cancel and it’s now flashing. Tried removing ribbon etc. and it did drain for 2 min. Reinstalled and normal still flashing nothing lease happens.
von Mike
OMG. Worked like a charm! Thank you so much (8 years later!)
von Dan Proskauer
So if pump comes on whitout P1 ribbon canle and when reassembled normal light still fais, I need to replace the outside control panel WPW10459139?
von PatD
