Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
GSM iPad 2 mit 16, 32 oder 64 GB Speicherkapazität und einem Dual Core Prozessor. Modellnummer A1396. Die Reparatur ist schwierig und verlangt Hitze und Hebeln.
188 Fragen Alle anzeigen
iPad 2 in a boot loop after a battery disconnect and reconnect
I replaced the back cover on iPad 2 and exchange all components to new cover including some being replaced new. When finished I power up to test all functions. I got a good boot and home screen but in less than 2 minutes in went into a boot loop with about 1 minute delay after boot before home screen appears then 1-2 minutes and boot loop and won't stop. Any suggestions?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Have you tried charging it for like an hour or more while turned off if possible?
von
I was able to fix it, what I did was go back and remove the logic board disconnecting the battery clean the battery contacts with alcohol allowed to air dry and reassemble. it worked perfectly no more problems
von
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
2 Antworten
Gewählte Lösung
In my case I did actually fix my own problem, I disconnected the battery by removing the logic board cleaning the connectors with alcohol allowed to air dry and reassemble. It worked perfectly no more problems.
Thanks guys for your input have a great day !
War diese Antwort hilfreich?
Bewertung 0
Hi Danny
Try to restore it to factory settings.
Hope this help
Bewertung 0
Antwort hinzufügen
Danny Hartley wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 189
