Zum Hauptinhalt wechseln
Ein 5-Zoll (12,7 cm), 1,4 kg schwerer persönlicher Exzenterschleifer von Porter-Cable, der 2010 auf den Markt kam.
Why is my sander not sanding?
I recently purchased a Porter-Cable 382 at my local home depot. I had been using it for weeks and haven't had any issues sanding down some objects. However I went to use my sander today and it is no longer sanding the surface like it had done so well before. The head is spinning but not sanding, please help.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
If your sander is not sanding there could be a few different problems. First one being you need a new piece of sandpaper, in which case you should replace the sandpaper. Your sand paper could also be too high of a grit making the abrasive surface not rough enough to do any real damage, try gradually using lower grits until the surface begins sanding. If you go too low and scratch marks appear just work your way up to higher grits. Your device could also not be operating properly in which case I would check this devices troubleshooting page to search for causes for various problems.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
jpfoxracing9 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 1,314
