Zum Hauptinhalt wechseln
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
368 Fragen Alle anzeigen
Replacement for rubber feet located at the upper back plate
Are there any website that sells rubber feet located at the upper back plate of the device? If not then is there any way to make it adhesive enough without using liquid-based adhesive like superglue?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @faux I got the easiest solution for you and here you go. http://www.amazon.com/Self-adhesive-Clea... I use these alot and even though they are clear they do the exact same thing and all you have to do is peel them off and stick them to whatever I use them on electronics, tool cases, Ifixit 64 bit kit and what ever I don't want to slide which is what those original feet did but they are just clear instead. I hope this helps
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
J Gab wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 658
