Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1623 Fragen Alle anzeigen
Why is my battery percentage inconsistent?
I bought a MacBook Pro 13" Unibody (Mid 2009 to Mid 2012) Battery on your website, and I've just notice on how the battery doesnt last long. It loses a percentage around every 4 minutes and it can only last up to 3 hours tops. Just now i was charging it and it says 100% but when i took of the power source the batter percentage became 65% immediately. please help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
When you put in the new battery did you reset the SMC or anything else?
von
I'm not sure. I had someone else put in the battery for me. Can i reset the SMC by myself right now? I also change my hard drive from an HDD to an SSD, i don't know if thats relevant or not.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try to discharge the Battery till the MacBook turns off. After that charge it all the way up to 100 %. Don't remove the charger during this process! This way you calibrate the battery sensor in your Laptop. Try it 3-4 times, if it doesn't work, you need a new battery.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
To reset the SMC follow this Apple T/N: Reset the System Management Controller (SMC) on your Mac
von
Reset the SMC if that wont help, replace the battery.
von
Antwort hinzufügen
Miza Marzuki wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 144
