Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
591 Fragen Alle anzeigen
Ifixit says I need 10600 RAM but OWC says I need 12800.
So I bought this RAM a while ago for my 2.4GHz MacBook Pro Late 2011 which is PC 10600 and everything seems to be working fine. ifixit says I have the right RAM for my computer but OWC says I need PC 12800. Can anyone confirm what would be best for my computer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
Here is the EveryMac spec listing of your system: MacBook Pro 13" 2.4 GHz i5" (Late 2011)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
As you can see EveryMac lists PC 10600 1333 MHz DDR 3 SDRAM for your system.
While you can use faster speed modules they do need to be the correct type.
The only difference between DDR3 and DDR3L is the L modules run at a lower voltage so they run cooler and give you a bit longer battery life when your on the run. Both will work in your system.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Erik Ashlie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 145
